Hi to All - First Question
amit.ishu
Delhi
Hi to all champs,
I am Amit and new to this community. Some days ago I was planning to buy either sony ht iv-300 or yamaha yht-196 because budget was max 25K.
Finally I bought iv-300 because YHT-196 has low bass and less features like bluetooth,usb....
After 2-3 yrs when budget allow I will go with either Yamaha/Onkyo.
So my first question here : How can I set dolby digital plus and/or dolby truehd sound in sont ht iv-300 while watching movie. system spec shows me it has both features.
hi amit,
to get dtsHD/trueHD, u need a disc which has following decoding i.e bluray disc or media in PC,
then check setting in player/amp if its set to play direct audio decoding from source.
hi amit,
Thanks Sameuun,
on star movies hd or other hd channels (using Vediocon D2H) for some movies or serial , it shows me Dolby Digital Plus on TV screen's left bottom corner, but I do not know how to set this sound on my home theater. I was hopping that if someone using Sony HT IV-300 and already know this setting ???
Thanks Sameuun,
Therez a limitation with current all STB that they dont have dtshd/trueHD even if u watching HD channels
Max u will get dolby plus which I think u getting now
And for HD audio passthrough i already mention u neeed bluray disc/ bluray iso if at all u playing through pc
Ok thanks bro...
Need your advice on Onkyo HT-3500, I am planning to buy it in near future and my budget is around 30-35K. Can you please suggest me a better option than this Onkyo HT-3500. My requirement is watching movies only and no matter If I put sound on high end, it should be soft and smooth and bass should be felt on chest not on ear.
