home theate 5.1 upgrade
gbhatia712
gurgaon
hello ..
i have samsung dvd home 5.1 home theatre (4 tallboy speakers). but the system has only one analog input as it is 6 years old. and now i am planning to buy samsung led tv with does not have analog audio out.
can anyone suggest what to do ... should i go for an upgrade in speaker system like go for "yamaha 196 " or "onkyo 3400". or there is another option of sticking to the older system..... please help !!!!!
well you can use it.hear it and then decide if you need to upgrade.RCA out of stb or TV into RCA in of your present system.
dony buy sammy led.
try sony led and samsung/panasonic plasmas.much much better picture.whats ur tv budget??
demo it with hd channels,high quality files,blu reay disks,side by side compare and decide.
yamaha 296/onkyo 3400/denon 1312xp all are very good entry level systems by the way
