Home theatre for 1 lac
maharajg
chennai
Hi Guys,
Im from Chennai, and looking to setup a decent home theatre with a budget of 1 lac. Pl. suggest a good setup. I would like to go for a projector and screen with this setup at additional cost.
Sr
Room size is 200 sq.ft. FS preferred. Separate if possible in this budget.
THanks Jice.
20 x 10 then consider FS ( if ur crazy abt it).
AVR - Try Yamaha RX 673 or Denon 2113
Speakers - Check out Sonodyne or Polk or Wharfadale diamond or Jamo
1 lac can be good budget for better AVR + speakers,need extra for Projector.Else need to compromise on AVR.
Thanks, dont mind spending extra for projector. Pl. suggest a good brand and model, being a newbie finding it difficult to narrow down, took a demo for magnat in chennai was impressive for music but not so much for movies.
Srini
If you are considering floor standing speakers, then I would always suggest to go for AV receivers having pre-outs. Having pre-outs will help you to enhance your HT setup by adding power amp. As far as I know, Marantz SR5007 is an AV receiver which has 7.1 channel pre-outs for the AVR budget around 50k. This is just a suggestion and you may want to audition your speakers with other AVRs as well.
I suggest you go with Yamaha RX-V673 and Q Acoustics 2050. They are very good speakers. Do not use polk with Yamaha as the result could be bright sound which will lead to ear fatigue.
THanks guys,
htstore suggested i go for Denon AVR2113 Tannoy V4 package with
Velodyne Eqmaz 10 subwoofer, is this a good bet?
REgards
Srini
