Home Theatre sound Recommendations for TCL 55P8 TV
You can consider a Logitech Z625 2.1.
If you are a bass lover, it'll keep you happy.
Other options are powered bookshelf speakers such as Edifier 1280db, Edifier 1700T etc. These don't give the same effect as a home theater but they do have room filling audio and are better than stock TV speakers. Can also be used for casual stereo music.
Another offering by F&D is its R60BT bookshelf speaker. Do give a listen before finalizing any of these.
What is the power consumption?
Any idea what are connectivity options via TV. does it have HDMI arc so I can control it via tv remote and so that it goes into standby mode when I switch off the tv?
[/QUOTE]
Hi, I don't think any integrated will have HDMI connections unless you are talking of high end stereo receivers. You have to connect using simple RCA connections. TV cannot be controlled.
Hi, I have a caution for you. Any decent HT system will cost you upwards of 60k atleast even if you go with the basic AVR and 5.1 combo. Many people have done the mistake of buying at a low budget quickly realizing that it doesn't do justice to bigger TVs or in general don't have the power to immerse you in the movie scenes. I also made the mistake of buying a basic Onkyo AVR and sold off within 3 months.
Without any disrespect to the suggestions given, I strongly suggest you to wait for some time and increase your budget.
If you cannot increase your budget in the near future or wait for any longer pl consider buying the Pioneer Amp A10 + Speaker BS22 combo at 30k available at hifimart. Trust me a quality stereo system will sound a lot better than an anemic HT system.
I may have confused you a bit but many are happier with a simple quality stereo system even for movies.
You decide what suits you best and keep us updated. Cheers
+1 this suggestion. My current Stereo Amp + Wharfedale book shelf speakers is beyond comparison with my earlier Sony Home Theatre 5.1. After an year I have added a Subwoofer, it is 2.1 now but it gives theatrics feeling in a small room.
