How Do I keep my Vinyls Clean?
The topic was started on 13th Nov which is before the Moderator raised eyebrows about starting new threads. Please check before you comment.
I think we're all getting trolled guys. This discussion seems to happening in a few other threads as well :D
[/COLOR]
Hi jayants,
Very good "DESI" method :clapping:which you are using to clean your LPs. I am also using the exact method to clean my records but i add a small quantity of isopropyl alcohol with the cleaning agent.
Can you explain the importance of the " static free plastic sleeves" to our FMs.
regds
shafic
Static free plastics helps resisting static buildup on the vinyls which is very important.Can check this ebay link 50 Anti Static Round Bottom 12" LP Record Inner Sleeves | eBay
I am also using the same method. But before keep under fan just spray 30% Isopropyl alcohol 70% distilled water solution by a hand sprayer and cover the spray by a soft sponge over the surface of record and wipe off by microfibre cloth.
Thank you for your suggestion.
You mean to say that I will cover the record when its wet after the spray is applied?
Not mean as cover the record... Here I mean just spread the solution over the record surface and then wipe off...
