How to clean a LED TV screen?
wouldnt suggest using colin....water should be good enough.
or go for those liquid laptop screen cleaners which are also water based...
A dry cloth,if there is some stains then use a slightly damp cloth,preferably lint free one.
Do not use collin and other chemical detergents/spray.
My choice is Microfibre cloth (like the ones marketed by 3M for camera lens cleaning).
Second close choice is a lint free old cotton cloth.
yes, Microfibre from scotchbrite can be used.
if used everyday no need of any liquid cleaner, also if you see dust in the screen, use a static duster first before using any cloth.
Colin will make things yellow over time. Avoid using colin on anything in general apart from mirrors and thick glass. Damp cloth + dry cloth is the best for almost everything.
