Hi All
I do not have a separate LFE out either in my source (WD Player) / DAC or in my Arcam A 28 Integrated Amp. My sub has a single RCA in.
My Arcam has preouts, and initially I connected the Left Channel to Sub In, I guess this is Line level without any filtering for Low Frequencies. This connection works.
Next I bought a Y RCA adaptor to connect both the Left and Right pre outs of the Stereo Amp to the Sub.
Today I realized that the Y RCA adaptor connected to the preouts is also mixing up the Front Speaker Out puts. With the result that I do not get Left and Right channel separation when I play a 2 Channel Track.
My queries:
a) How do I feed both Left and Right channel signals to a Powered Sub with a single RCA in? Are there any other subs with two separate inputs that do not mix up the signal upstream for the Fronts?
b) Is it OK if I connect the Sub to one channel only? Does it introduce an imbalance in the L & R speaker outputs?
PS: I know that that the purists will frown at the idea of connecting a Sub in a stereo set up for music. But I feel some tracks sound better this way
My queries:
