How to make Sony BDP S360 BD player region free
bhaiji
Dear ALL
I have purchased one Sony BDP S360 BD player from US last month.
I was not aware that these players are having region code and we can not use them in India.
Can some one tell how to make this player region Free to play DVDs and BDs?
Thanks a lot in advance.
Bhaiji
Dear ALL
Bhaiji
You are in a Fix, MODs on Sony players are pretty tough, try the options provided by idlebrain or svenket,..........should have gone with Panasonic DB60/80.
Dear All,
So far I tried all the options and so far nothing worked for me.
Waste of $175 ...
Keep me informed if any one found anything else to make it work in India.
Mukesh
Dear All,
Waste of $175 ...
Mukesh
Mukesh, look at BDs very carefully when buying them from the local market. If they're multi-region, they will play on your player.
There are few discs that are not multi-region and those are clearly labeled as such. stay away from those as those will not play in your player.
