HT 5.1 with priority to music
codeanand
bangalore
Guys,
Budget is 25 - 40k
I want to enjoy south indian music. AR rahman type.
Here are the options i am currently considering.
1. Onkyo 3500
2. Yamaha 298
3. Poineer rs 32. (Tower)
tower speakers look awesome.
Please advice.
If you can stretch your budget- For Music I would look at Paradigm Cinema 100 CT v4 (5.1 system) Speakers with Denon AVR 1513 Receiver-- It is an excellent starter system
whats the cost of it?
where can i audition it in bangalore?
And its satellite speakers right? wouldnt i be better to go for tower speakers at that budget
It will run you around Rs 80,000
IMHO- Good sounding Floor Standing speakers will cost you a lot more
Check out Rontek Systems at +919845047290
Start with the Front- Left and Right speakers-- With a A/V Receiver--
You can always add the Center, Surround and Sub later- as your budget allows
Agreed.
I started with denon 1312 with wharfedale diamond 10.2. it was basic stereo sys hooked to tv , asus media player. Later subwoofer was added. finaly yamaha centre and surround were added.
i am enjoying music as well as movies.
hope to own a dedicated stereo sys in future.
Suggest you to look for energy take classic, it has got lots of positive reviews, i guess for your budget it should work well.
If you prefer music then Yamaha 373 and Polk TSi 200, later when your budget will permit add a centre channel and surrounds subwoofer. Trust me this will be the best way.
Otherwise you can try Wharfedale MS 100 HCP and Denon 1315 / Marantz receiver.
I have Wharfedale MS 100 HCP and found them to be very musical as compared to other HT package.
