Lovely. I rem the demo I took 2 years ago and I was indeed impressed by the rumbling bass. I am still surprised that to get similar low end performance, I need to spend a similar amount just for the subwoofer.
My primary desire is for deep bass, and I recently went down the rabbit hole researching setups. My budget is around 60k, and initially, I thought I needed a whole AVR setup. The plan was to start with just the AVR (eating my whole budget) and 2 speakers, then save up for a subwoofer later. But then I saw the comments about the JBL Bar 5.1...
The JBL Bar 5.1 (510W) is going for 60k on Amazon, I want to make the right choice. So, here's my dilemma:
How much would an AVR setup cost to match the bass of the JBL Bar 5.1 which you auditioned?
How's the overall sound quality of JBL bar 5.1 compared to an AVR setup? Is it a night and day difference?
People say soundbars are bad for music, but are okay for movies? Why?
Are there advantages to the AVR route beyond upgradability and longevity?
Does the JBL Bar 5.1 lack good sound imaging since all front channels are close together? Will it make it seem like all the sounds from the front are coming from the middle, leading to poor sound imaging?
Some folks say the Logitech Z906 competes with the JBL for bass. Should I consider it?
Both JBL and Logitech only offer 1 year warranty. How long do these systems typically last? Compared to an AVR setup?
Budget Breakdown:
AVR: Initial 3.1 setup would cost around 50k for AVR + 60k subwoofer + 60k speakers, requiring me to save up for each piece.
JBL Soundbar: One-time purchase (50-60k)
Logitech z906: One-time purchase (30k)
Is the overall sound quality of soundbars THAT bad compared to a custom HT setup?
Basically, if the JBL bar 5.1 or Logitech z906 can deliver as powerful bass but with a slightly worse sound quality, that might be okay. But can they compete with a custom HT setup for that deep, room-shaking experience - the kind of bass that is not just a weak rumble in the seat but is powerful enough to be physically felt rumbling through your chest and travelling down your body?
