I am new here, I intend to set up a 5.1 system.
Currently I own a Cheap 2.1 Sony SRS D9, which I intend to discard.
My knowledge in terms of what is "good setup' available in the market is limited, so please advice me on building decent setup
Budget : Rs 50k to 1L, I wont be buying the whole set up in one go due to funds constraint, what I intend to do is first purchase an AVR and stereo speaker than a sub and than central and than surround speaker.
My general use will be playing games via PS4, watching youtube videos and movies.
Source will be PS4 when playing games and smart TV (43W950C) when watching youtube, spotify or watching movies via external HDD.
Music/Sound Preference: Generally I prefer more bass, the one which makes you perfectly enjoy the music of artist like daft pund, weeknd, drake (I am into electronic, hip hop, rock).
I don't have technical knowledge, so cant really tell what frequency response should the HT have, so I will detail in laymen terms what I require, enough bass for properly getting the feel of hip hop/electronic music but at the same time I don't want to compromise on the sound clarity.
Room Size: 18 Feet X 10 Feet X 13 Feet
Here you can see the postion of TV and I will sitting on the bed for majority of the time.
In the below picture: Fridge and big table on the right hand side will be removed from the room.
Picture of the room from one end to other end.
I live in Delhi, if you can suggest some good shops where I can audition the same before buying will be helpful.
Feel free to ask me if you need any more info.
Thanks,
Abhi
Thanks,
Abhi
