Hi guys, I have posted a thread long back and couldn't setup the theater then but its back on track now. We have a dedicated room for home theater with dimensions 26*19ft (19 being the screen side). I am looking to get the acoustics well made with ply,rock wool,fabric,vineer/laminate and everything that's need for a dedicated HT setup. I am looking for 7.1.2 setup. I have a budget of 8-10 lakhs for both equipment and acoustics included.
1) I have been quoted about 450-600/sft for the acoustics. Is that reasonable or too expensive? Would it be better if we give it on a turnkey basis or provide them the material and get the work done?
2) I am looking to make the acoustics well made and go with a decent speaker setup which i might probably upgrade in 3-4 years, but something which would be good and my main purpose is to watch movies.
I have had a chance to visit and audition polk tsx550 and rtia7's, focal, bose. I felt polk tsx550 was good and rtia7 was a little strong but i heard both of them in different setups, so that could be the difference. Anyways i am open to suggestions about brands but i am looking at a good av receiver since that drives everything.
3) Is it better to have 2:35 or 16:9 screen? Also what size would be ideal.
4) Also please suggest good projectors which have a good lamp life and 3d is not a compulsion.
Thank you in advance, your suggestions and help in this regard would be greatly appreciated. I am looking for all this in hyderabad, if that helps
