HT setup
dpdcp
Hyderabad
Hi friends,
With the help of this forum i started my home theater journey and taken the advantage of Superior experience of watching the movie.
Now I had Denon 1312 avr, PSB alph B1 fronts, PSB clr1 centre and PSB LR1 Pair as rears. Still using Denon sys subwoofer.
My new flat will be Ready by the end of July 2016 in which my Living room can be used as Home theatre room having size of 15ft x 12 ft.
Planning to buy projector, screen and Subwoofer. Kindly help me the brands and models for the same.
My budget will be around 1 Lac.
You can get chinese motorized screen for 15k (100 inch diagonal is sufficient for your area), a decent subwoofer for 30k and a projector for 55k (provided you buy it overseas and ship it to India). I highly recommend buying projectors overseas as the retail margins here are highway robbery. If you buy it from Europe, then step down transformer is not required.
