HT System for Less Than 150sqft room
pintu
kolkata
Hi!! Everyone,
I'v a room less than 150 sqft.
I would like to buy a HT system for thsi room.
I have decided to purchase the following
Sonodyne Genie 1,Rorar 108,Yamaha RXV 373
My question is should I buy the above configuration for my little Room?
Thanks in advance
Pintu
Hi!! Everyone,
Thanks in advance
Pintu
You can consider the Sonus range speakers also if your budget permits....1501 BS + C2401 + dipole rear's...It will help you have a good balance between stereo/HT needs... Juz my thoughts...
