Am planning to convert my old rig in to an HTPC ....will be using these components
CPU - AMD athlon X2 3ghz
Motherboard - Asus M2N 68 AM+
GPU - XFX GT 220
RAM - Transcend 1X2GB DDR 2 800hz
Monitor - AOC 19 inch, will connect it to Sony Bravia 32 inch later
SMPS - Stock , came with the local cabi
HDD - Seagate 160 gb, Buffalo external harddrive 1tb
Speakers - F & D 6000 , 5.1 set up ..
Will be using the HTPC for
Watching TV
HTPC
Watching HD movies
Occasional gaming if i am around - COD, CS
The HTPC will be connected to my AOC for the time being , will connect it to sony bravia 32 inch screen later on ..
Need help with the following components..
1)Cabinet - Zebronics Flair , had some doubts though, can it fit my CPU cooler that comes with AMD procy, and the expansion slot does not seem to fit my GPU either, but the vendor told me that i may be able to shorten the GPU panel length ??
2)TV tuner card - have no idea about which one to buy , the ones on flipkart look line ...need some suggestion regarding this ...
Motherboard - any compatible motherboard
AverMedia AVerTV SUPER 009 TV Tuner Card | Tv Tuner Card | Flipkart.com
AverMedia AVer EZMAKER SDK TV Tuner Card | Tv Tuner Card | Flipkart.com
Hauppauge WinTV-HVR-1200 Media Center Kit TV Tuner Card | Tv Tuner Card | Flipkart.com
Frontech FT JIL 0606 Internal TV Tuner Card | Tv Tuner Card | Flipkart.com
The TV tuner card will be connected to the local cable and probably later to the set top box ..tata sky or something of that sort ..suggestions are welcome for the same ...
The tv tuner card is basically to watch the tv programmes, recording them is not a priority , neither will my parents be able to do it on their own ...
3)A good HTPC remote ... please suggest whr to buy them from ???
USB Wireless Remote Controller With Receiver for Laptops & Desktop pc | eBay
PC Remote Control And USB Receiver | eBay
anybody has any experience with these ?? are they worth buying ?
4)A wireless keyboard , preferably with lithium ion rechargeable batteries, dont want to keep changing the batteries...
Logitech K400 Wireless Keyboard | Keyboard | Flipkart.com
this one needs batteries to be replaced though ...
GPU - XFX GT 220
Watching TV
HTPC
Watching HD movies
