I want to buy Wharfedale DX-1 Hometheater
idlefriend
hyderabad
I want to buy Wharfedale DX-1 Home theater.Where I can get cheap price.I want to audition in Hyderabad.Please let me know the shops in Hyderabad.
Thanks in advance.
Audition is possible only through Home Theatre dealers in your area and perhaps a google search would yield some names who you can call before going in for an audition.
All the best.
All the best.
Thanks.I am going to audition DX-1 in vector systems hyderabad on 2nd of October.
do they have it in stock for demo
Yes.But only for DX-1 model but not for MS-100.They are saying we have to buy it directly for MS-100.
I am little bit confused.Which model is best DX-1 or MS-100?what are differences in both speakers?
Denon AVR X2000 is suitable for DX-1??Please suggest me.
Denon X2000 is good match for Wharfedale. But I would suggest you to also audition Yamaha AVRs. They can complement Wharfedale Better.
The Wharfedale MS100 are small speakers with a single 3" (75mm) driver.
True the Wharfedale DX-1 has the same or simliar 3" driver but they are in bigger cabinets, and they have a tweeter.
Either way, these speaker are mostly limited to Movies, they are not meant for music.
Thank you so much Rupam Bro.My requirement is 60% Movies and 40% music.Now suggest me which one is better.
Today I auditioned DX-1 today but only front two speakers with central speakers sub woofer and rear speakers are other brands. sound is good but I was not able to judge about bass because sub woofer is other company.cost is 67k+ 2%tax.
