Please provide latest Oreo update link or manual update for iffalcon 55k2aYes you can update manually. i tried this and very happy with the results. The tv runs much smoother and faster now. I don't know if installing 8.0 Oreo manually voids your warranty or not. Research before you update.
Any links on whats the difference between 544 and 549?Download links for different versions of iFallcon 55k2a which has CHASSIS : MT5658.
I am currently on V544 and is quite stable and NTFS drives works fine.
Use it at your own risk.
Android Oreo
V546:
V544:![]()
V535:Google Drive - Download warning
drive.google.com
R549:
Here are some more versions from Australian TCL website.
https://support(dot)tclelectronics.com.au/software-version/
How to update:
1. Turn off the TV (TV mains plug power off)
2. Copy the firmware to the root directory and insert the FAT32 formatted USB stick.
3. Press and hold the power button on the TV.
4. Turn on mains power to the TV (while keeping the power button pressed)
5. TV should detect USB drive, after about ten seconds, you will see the upgrade notification on the TV.
As soon as you see this, release the power button. If it doesnt detect USB pendrive, try it with a different one (less than 32GB).
The TV will now update and may take upto 20-25mins. Do not disconnect
or press any buttons, until you see the Google welcome page. The update is now done.
Use VLC it’s much betterHi,
Me too facing the same issue after updating to Oreo
Does the latest build v546 version has amazon prime in google play store or any other difference??Any links on whats the difference between 544 and 549?
Also whats the improvemnt u have noticed after update
I received message don't turn off, but what after that,Power off the TV, hold the power button in remote and power button on TV at the same time until ,u see a screen saying "don't turn off "
It restarted n again boot going on on on
Please help for next
Do you have ThopTV installed? I had similar issue and ThopTV was causing it.Hi All,
My 55K2A tv keeps triggering google assistant randomly, i tried to remove the batteries from remote to check if it was any faulty button and also tried to factory reset the unit still same issue. I don't want to disable the Google assistant app as ots handy for voice typing. Kindly suggest any possible fix for this issue.
Guys, my 55k2a suddenly went black today. So the screen stays black (as in turned off) when I turn the TV on. Once it is fully on (still display off) I can turn it off using the Remote. Means it is turning on but no display. Tried calling Jeeves (as it is still under extended warranty) but no response (due to lockdown).
Is there any chance it could be fixed at home via some reset or something? I will hate to be without my primary source of entertainment in this lockdown!
I am having trouble converting my USB drive to internal memory. My TV recognises the USB drive and then I erase and format as device storage it shows USB drive not connected under device storage but shows up under removable storage again. I want to increase my internal memory to add more apps and cache space. Do I need any specific USB stick or is there any settings I need to update.
