rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,668
- Points
- 113
Install media player classic home cinema. The latest version has lav codecs integrated. Setup lav to use DXVA2 copy back. Then download madvr, put it in a convenient location and run the install script. Set media player classic home cinema's output to be madvr. Play any movie. The madvr logo should appear in the task bar. Double click it and go to scaling algorithms. Set chroma upscaling to jinc 4 taps and enable the anti ringing filter checkbox. Do the same for image upscaling. For image downscaling, select lanzcos and enable the anti ringing filter. That's it! Your machine is setup for state of the art video playback now.
When I try to enable madvr after installing it with a batch file it says unavailable in the output window of media player classic
Any idea where I can be going wrong? Or madvr wont work with media player 64 bit?
32 bit does not have lav inbuilt
