Indiq audio Diamond Mishra vs MartinLogon Motion 4i
Phani24
Vizag
One of my friend Looking for soeakers for sterio
Pupose. He want to go with Martin logon 4i. And suggested him indiq diamond mishra. He mainly needs good vocals than base. I heard great about indiq Diamond mishra. Please suggest.
If you need good vocals try, harbeth, proac, falcon, atc, spendor, rogers, graham etc. most of these are good at only small to medium rooms and they cannot go very high volume.
I have not heard the Indiq, but the Martin Logon 4i has poor fidelity. Mid-centic, but resonant, very bright highs and stagnant lows.
Look at Elac DBR62, Concept 20 or the Wharfedale 12 series. Have not heard Fyne Audio, but good reviews.
I am using Indiq and the Vocals sounds very lively, natural and with greate presence of clarity. It is a VFM product and the owners are very happy.
Diamond Mishra will not find many equals with your listening preference and budget.
Same can be said with the service you will receive from Amit.
That true, Amit will not keep stock of speakers, except the demo pieces. As per my understanding, every speaker irrespective of their value, is made to order and it takes time to deliver, some time couple of months based on the back order. He collects the information on our setup and preferences, and ready to tune or tweak the speakers as per requirement (if it is possible within the budget and the model we have opted). Any how, being a music lover, with the constrained budget and very humble and vintage setup, I am a happy customer. It is nice to see that, still there are couple of such speaker manufacturers in the Country doing good things in a very small segment of hifiaudio under tight competation.
Hi, can you share - what's in your set-up?
I think I am not using my Achal's properly :)
Are you using Indiq speakers ??
Is there an Indiq user group on the forum? I would like to join and see how others are using them.
I can't even find a Facebook page with Indiq owners or enthusiasts.
I use Indiq Diamond Achals for both music and movies. they perform great with the AVR for movies and also with an amp for music. never felt the need for any subs while listening to music in the 2 channel stereo setup.
you can demo and decide.
