Integrated Amplifier under 60k ? US/Singapore?
krishpiscean
Hyderabad
Pls suggest good amps under 60k. I have option of getting from US and SG markets. Denon/marantz/yamaha/nad are not in race due to personal taste.
Speakers would be either Monitor audio or B&W BS/FS.
Currently in contention - Rotel RA-06SE/Rotel 1520
Can i get a decent pre/power amp combination is this budget ?
Hi, Am also visiting SGD... Is Rotel better than Marantz for Rx6? Where in SGD do you get these cheap. Also is warranty an issue?
For 60k, I will be looking at the Musical fidelity A5 (250w/ch) amp on sale by our forum member. That's straight 1L off from MRP.
I have finished system matching my setup. You are welcome for audition.
The member lives in a short drive from madurai.
from usa, you should be able to get a whole lot of quality integrateds below $1200 (around Rs 60,000).
but know that power is a vital issue and using a stepdown transformer in india will have its disadvantages.
but there are certain sellers in the usa, who will switch the voltage to 230 volts for you for a small charge (a seller for jolida on audiogon - underwoodhifi - does this for jolida; might do it for musichall as well - and his prices seem significantly lower than market). or brands like creek come with a dual voltage switch.
