Integrated amplifier and budget streamer in 45K
I would say for amp, Pm6007. I have it and it is very good. Prev i had yamaha as500, which ivhave now also but dont use.
If your source is tv headphone out, then bass will not be to your liking, and neither the mid range. Some digital input to amp is preferred.
Now, if you don't want to but streamer for now, there is a good bluetooth receiver, called as blume Pro. I have that. And it is very very good. I never had liked bluetooth in past, but this changed my opinion. So here you can use your iphone also to lisyen either via spotify, youtube, or anything.
Thanks @vkalia. I agree with you after my today's audition of another amp, same speaker.
I did try moving speakers away from the wall (greater than 200mm recommended, and little closer) tried to experiment with little toe in and I think it is helping. Overall as I said for the Music, I am happy , esp the details and stereo separation is amazing.
By the way, I did try Yamaha RN-602 with the same speakers at Oceanic Music today. The overall sound was okay and same as my speakers although a different amplifier, the overall mid and bass was much as I had observed. Specifically for the Amp I did not feel it any better than Marantz PM5005, a little more neutral plus the 'Loudness' control on it was turned way up high. For few different songs though, turning the 'Pure Sound' mode seemed a little better; a little more clarity.
I may be getting a used RN803, which is regarded above RN602 and has room correction. So my final choices are :
1. Yamaha RN803 (Used) (Little apprehensive to buy this used especially since its not from known forum)
2. PM6007 New + Would add an android box ~3-5K (Liking the overall Marantz sound, hoping the inbuild DAC would surely improve the mids in the TV sound)
So, what did you end up with?
