ghost31182
I need help with choosing a MOBO , Processor, Case for my new HTPC build.
I have a spare MOBO lying, Intel DH67BL and my computer's MOBO is Gigabyte H77D3h I want to build a HTPC separately. which MOBO do I use? I can use either of them, please suggest a good case, processor for the HTPC build.
I'm planning to get Edifier DA5000Pro to hook it up with my HTPC, any other choices ? budget is 15k Max.
I will connect the speakers to my computer, now If I play TV how do I get the sound? should I connect the speaker to tv? if I do so , will I get surround sound?
Thanks a lot
Thanks a lot
