Intel NUC - Fully Loaded
Yup, Just received the shipment.
Not opened yet. However from the looks of it,
looks like no RAM and HD
Guys, Looks like we have been taken for a ride and
I dont like it. What do we do?.
Received mine also.
It is without RAM and HDD. Didn't open the seal and requested Amazon CC for return. Will be picked up tomorrow.
Chat with Amazon:
Me: Please refer the Order #
402-5072496-1869901
RAM and HRD is missing in the received shipment
Amazon: Hello , my name is Asker. I'll be glad to help you.
Me: Ok.
Waiting for your reply
Amazon: Let me check this for you. May I place you on hold for two minutes while I look in to this for you?
Me: You may pleae
Amazon: Thanks for being on hold.
I have checked this for you and see that the The RAM and Hard dick does not come seperately.
They are inbuilt with the system.
Me: Good to hear that. But the product brochure says otherwise. But upon connecting to AC the HDR LED light is not blinking,indicating no HDR.
Amazon: Please Hold on for a moment.
Me: OK
Amazon: I see it is taking some time to review your order. May I place you on hold for another 2 minutes, while I look into this?
Me: Its OK. Let me have lunch. Meanwhile please reply but do not disconnect for want of my reply.
Amazon: Thanks for your time.
I have checked this with my internal resources, But I could find any technical information about the product, I am so sorry for that.
In this case, i request you please contact the Intel technical support team using the below link
http://www.intel.com/p/en_US/support/co...(see full link)
There you will get more details about the product.
I hope this helps.
Our chat has now been idle for 5 minute. Please either close the chat or respond within 30 seconds if there's something else I can help you with. Otherwise, I will disconnect this chat.
If you have any issue after contacting the intel, please get back to us, we will take the item back and issue the full refund
Thank you for contacting amazon.in customer service. You have a great day.
No worries gangasjith. :)
So, how hassle free are Amazon returns?. I have bought a few things but
never returned one.
I have decided to file for a return and go the ebay route.
Can some one suggest me a good 4GB RAM?. What is the
difference between DDR3 and DDR3L?.
If it's too good to be true, it probably is...
However, I'd highly recommend leaving feedback/review on the seller. At the very least it will warn other people.
never returned one.
My experience has been good so far with Amazon returns. Hassle free.
DDR3L is DDR3 memory but has lower voltages, (eg.1.35v & 1.25v). You need 1.35V DDR3L RAM. I think standard DDR3 RAM has 1.5V.
Thanks mgdelhi for the coupon.
I filed a return with Amazon.
I placed an order for the following items from ebay.
Intel NUC KIT DN2820FYKH Mini PC With Wifi Bluetooth Hdmi USB 3 0 Ports | eBay
Crucial Laptop RAM 4GB DDR3 1600MHz Sodimm CL11 PC3 12800 1600 MHZ 1 35V | eBay
Samsung 256GB SSD 6GBPS Solid State Drive 100 Tested Genuine 500 Already Sold | eBay
All worked out to Rs 16589 and on applying the coupon came down to Rs 14930.
I am taking a risk with the SSD (as there is no warranty) but I see lot of satisfied
people from this seller, hence for the price vs performance ratio, I decided to
take this risk.
As I had indicated in my earlier post NUC comes without RAM & HDD.
However with additional Rs.4000/- for RAM & HDD is not very bad.
You need to take care while selecting DDR3, which comes with 2 operating voltages. Here we need low voltage device. i.e.1.35V low voltage memory
Moreover the processor although mentioned as 2820, may be actually 2830.
That needs to be checked, because then for 2820 you need RAM with 1066 MHz SO-DIMM & if it is 2830 then 1333 MHz SO-DIMM.
The 1333 MHz SO-DIMM will work for 2820 but frequency will be limited to 1066 MHz.
It is also to be kept in mind that we need to update bios to suit, which OS you are going use. For that zipped folders for the bios are available on INTEL's website.
I received NUC just now from Flipkart, which I booked on 13th April eve.
Not yet opened. Will post my impressions after opeing/ unboxing.
My package was also picked up by Amazon today.
I should be getting the NUC I ordered from ebay tomorrow. However
I see no signs of my RAM or SSD being shipped. I hope to receive
everything by the weekend so that I can setup and experiment over
the weekend.
Opened the box. Here are the photos.
Today I will purchase 4gb RAM (Rs.2200/-) & 120GB ssd Rs.4000/- from local dealer & get it fixed from him & getting it worked from him, as I am not that techno-savy to make it work. More after successful implementation.
I've ordered a Celeron based NUC from the same seller as sivakuru has. Same RAM too. Thanks for the links, mgdelhi and sivakuru!
For the HDD, I'm sticking with a 500GB Toshiba Laptop HDD.
And thanks for the discount code, mgdelhi! That's what tipped me over the fence I was sitting on, for the last one week, heh heh. After all the discounts, the total bill came to just under 14K.
sivakuru, a friend of mine has bought Samsung SSDs from that seller before. You can be sure they will be ok. You can't beat the bang for the buck at that price!
Yup, it was gangasjith and mgdelhi who made me cross the fence and
buy the NUC. I had been contemplating the NUC for a while now and
it was gangasjith post/thread that ignited the flame in me to buy the
NUC, but that turned out to be a disappointment and got me frustrated
and then came along mgdelhi with the discount coupon and it opened
up a possibility from ebay and bingo, I got all the components at a much
better price.
Thanks for the assurance on the SSD, I was initially hesistant, as there
was no warranty, but there were so many +ve reviews on this SSD from
this seller, so I went ahead. It does comfort to know that some one
we know also had bought and it is in good condition.
BTW my NUC has arrived, but yet to get the SSD and RAM :(
I will be installing OpenElec on a thumbdrive and Win8.1 from SSD.
OpenElec so that I can watch movies (with HD audio) and Win8.1
for YouTube, JRiver etc.
I will update once I get all components and install everything.
Ultimately I purchased the 4GB RAM 1600Mz DDR3L Transcend make Rs.2200/- & SDD 120GB Kingston make Rs.4000/- and got assembly & installation done from the same dealer in Pune.
It worked flawlessly and very fast.
I will post further after my hands on overall experience.
I received the RAM and SSD and installed everything. The SSD is in good shape.
Installed Win8.1 on SSD along with Avast, kodi, rdio desktop application. Yet to
install JRiver. Installed OpenElec on thumbdrive.
The boot time is pretty fast, takes about 30 secs to the point I can start Kodi.
I had earlier used kodi on my laptop, OpenElec on other pentium system and I
used to see some stutter framerate issues, thought those were because of
processing power, anyways, this NUC plays all those flawlessly.
The original plan was to use OpenElec for movies and Win8.1 for rdio, JRiver,
YouTube etc, but getting to Kodi (via Win81 including 8.1 boot etc) seems
to be faster than OpenElec running on the thumbdrive. Besides my lenovo
n5901 wireless keyboard does not have fn keys to get into boot menu. I
dont want to use a wired keyboard nor buy another wireless keyboard. So
for now it would be just Win8.1 Kodi for movies.
I am very happy with the performance, form factor etc.
Thanks to sam9s, musicbee, gangasjith, mgdelhi who were influential
and helpful in one way or other in this purchase.
If anyone has any questions, I will be more than happy to answer them.
