interest check for some pre-cabinets
kaushik
got very busy due to job .
just got hands on with pre cabinets
i can offer @1350/-
They are very nicely coated brushed aluminum ones suitable for pre /mini amp builds !
Size 128*54*164 mm ones ;)
pics here
Interested people can comment or put questions !!!!
no group buy needed , i hated GBs as they run very long .
I will stock 5 pcs lot and once it is at my place will ship at actuals per member 1 cabinet so that many DIY people can get it .
Long bump up...
I need a local source for the type-1105 cabinets that I'm now sourcing from Chinese vendors on EBay. They're almost exactly the same extruded aluminium cabinet as the ones on this thread, but outer dimensions are approx. 208 mm x 115 mm x 48 mm. The key dimension is the 208 mm depth - anything smaller and my electronics won't fit, they're already very snug-fitting.
The front bezel is brushed aluminium with one small drilled hole for an LED, and a bigger countersunk hole for a potentiometer + knob. The rear panel has a IEC inlet cutout, a push-fit mains switch cutout and 6x drilled holes for 4x speaker binding posts and 2x RCA.
Pic shown in this post:
http://www.hifivision.com/diy/44488...o-amplifier-built-beginners-6.html#post590177
Please let me know if something similar is available at or close to the Rs.1350 price you quoted earlier.
