Hi Guys,
I am faced with a weird problem with my setup. My left FS goes completely blank, no output whatsoever.
When I disconnect and reconnect the wire the sound immediately comes back and stays on for some times. Some times it stays till I power down my AVR, sometimes 3days at a stretch without any problem; then goes blank again. Checked with tester and there were power in FS, so ideally wire should be left out
I have tried various troubleshooting, re calibrated entire setup, swapped wire between right and left (when I swiped the same problem can be observed in right FS). Question is what is wrong here?
i had my system Bi-wired, post the problem I have made it single wired and the same problem can be observed in both the wires connected individually.
Checked with tester and there were power in speaker, so ideally wire should be left out but still no sound. This happens irrespective of source TV, BT, Android box or in FM.
Which unit is at fault here? My AVR, Speaker or wire?
My Setup:
AVR: Denon 540BT
Speaker: Taga Harmony TAV 606-SE
SW: Taga TSW 200
Apologies for the long post and thank in advance
Thanks,
Suman
My Setup:
AVR: Denon 540BT
SW: Taga TSW 200
Thanks,
Suman
