Introduction
My name is John and I’m a retired telecoms engineer.
To keep my hand in, I am trying to fix a Dansette Tempo record player (1960s) for a friend so I will be accessing the site for help and advice!
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
Great to have you on here. Thanks for joining.
