Introduction
JishuTV
Gurgaon
Hi I am Jishu from Gurgaon, i do much research before i buy new TV hence i found this forum. I currently use LG UHD SK8500, Samsung FRAME, LG G3 and QNED 88T
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
Hi My name is Franklin Shaw and I am new in the community.
Welcome to HFV.
All the best!
