IR Blasters
Anup, you will not find IR Blaster in regular shops. You have to find a dealer who can get one configured/made for you or get one from a regular manufacturer.
What is an IR Blaster any way?
An IR blaster is a receiver/sender that extends the IR signals from your remote through a cable. Many times, you may not able to place your equipment in a direct line-of-sight or directly in front of you. You may, at times, have to hide some equipment inside a cupboard or behind dark glasses.
What you do in such cases is to stick an IR repeater in front of the IR sensor on your equipment. The repeater is connected to a common box that has all the IR repeaters plugged in. The box is then connected by a cable to an IR receiver that is positioned openly in your line of sight. When you use a remote control, the signals are picked up by the receiver and simply transmitted to the IR repeater that retransmits the signal to the unit's inbuilt IR sensor.
Though you need only two cables to carry an IT signal, mostly the connection is done through a CAT 5 cable that can also carry other signals.
Anup,
Were you able to get the IR blaster in India?
If yes then from where and for how much?
I want to also buy this for my HT room.
Thanks,
Alok
Were you able to get the IR blaster in India? If yes then from where and for how much? I want to also buy this for my HT room.Alok
I know a guy in Chennai who makes this. I have seen it working in many places. It will costs some 2500. If interested send me a PM.
Hello Venkat,
I also wanted to purchase the ir blaster and tried sending you PM twice. I do not see any error while sending but I do not see my messages to you in the send items. I am guessing some technical problem and the PM is not working.
Can you please help me find the dealer/manufacturer of the IR blaster in chennai.
Thanks in advance.
Sabarish
