but not amp assign, speaker distance, speaker level, crossover, etc. and a bunch of the options available on the menu accessible through the physical remote are not available on the App! Am i doing something wrong here?
Some details of the app:
•Bug fixes
Notes:
*Please update the firmware via the system setup menu. (General > Firmware) If the App doesn't work properly, please try to reboot your mobile device, unplug the power cord of the main unit and reinsert into the power outlet or check your home network.
*Please set "Network Control" to "ON / Always ON" in your product via the system setup menu to use this app.
Control Application for latest Marantz Network AVR (from 2014 year)
Designed from the ground up for Android, the “Marantz AVR Remote” app for Android Phone and Tablet devices will give you an unprecedented level of command and control over the latest generation of Marantz network AV Receivers (due to hardware differences, older models are not supported with this app. Please check the model compatibility list below; if your model is not listed, please download our previous “Marantz Remote App”). A wide portfolio of useful features, nicely designed graphics and easy to operate user interface do make the app a useful tool to control your AVR.
Control the basic functions of your Marantz product with power, volume, input and settings. Have direct access to Smart Select and Surround Modes.
Network browsing is either done with the Marantz AVR Remote app or depending on model by selecting HEOS network as input which opens the HEOS app automatically.
With the Marantz AVR Remote, your Android device just became an integral part of your home entertainment experience.
"Because Music Matters"
Compatible Marantz Models (*1, *2)
2021 New Models
Network AV Pre-Amplifier AV8805A
2020 Models
Network AV Pre-Amplifier AV7706
Network AV Receiver: SR8015, SR7015, SR6015, SR5015, SR5015 DAB, NR1711
2019 Models
Network AV Receiver: SR6014, SR5014, NR1710, NR1510, NR1200
2018 New Models
Network AV Pre-Amplifier AV7705
Network AV Receiver: SR7013, SR6013, SR5013, NR1609. NR1509
2017 Models
AV Control Amplifier: AV8805, AV7704
AV Receiver: SR8012, SR7012, SR6012, SR5012, NR1608, NR1508
2016 Models
AV Control Amplifier: AV7703
AV Receiver: SR7011, SR6011, SR5011, NR1607
2015 Models
AV Control Amplifier: AV7702mkII
AV Receiver: SR7010, SR6010, SR5010, NR1606, NR1506
S2014 Models
AV Control Amplifier: AV8802A, AV8802
*Not compatible with Marantz models other than the above models. Please use Marantz Remote App for previous Marantz models which support App control.
Main feature:
•On the fly HEOS app switching for network browsing and control for HEOS built-in AVR and AVP
•ECO Mode setting
•Option settings (Sleep Tone, Channel Level etc.) and Selected Setup Features
•Marantz CD Control when your Marantz AVR is connected to Marantz CD Player with a remote cable
•Viewing User manuals
•Multi-Language Support
Notes:
*1: Please update the firmware via the system setup menu (General > Firmware). If the App doesn't work properly, please try to reboot your mobile device, unplug the power cord of the main unit and reinsert into the power outlet or check your home network.
*2: Please set "Network Control" to "ON" in your product via the system setup menu to use this app. (Network > Network Control)
Compatible Android devices:
• Android Smartphones or Tablets with Android OS ver.5.0(or higher)
• This application does not support smartphones in QVGA(320x240) and HVGA(480x320) resolution.
Confirmed Android devices:
Samsung Galaxy S10 (OS 11), Google (ASUS) Nexus 7 (2013) (OS 6.0.1), Google (HTC) Nexus 9 (OS 7.1.1), Google Pixel 2 (OS 9), Google Pixel 3 (OS 11), Google Pixel 6 (OS 12)
Caution:
We do not guarantee that this application works with all Android devices.
