santnai
Is Vinyl better than CD in terms of sound reproduction? Which is better? Keep floating your ideas.
Santosh
Santosh
I'm sure it will sound better than any CD provided you have a $150K Clearaudio Statement Turntable to play your vinyls.
What a waste of Money !!........
Are apples really better oranges?
Is it conceivable to come up with a modern analogue media? I'm imagining something like laserfollowing a microscopic image in the same way that a stylus follows the groove.
There are two points here.
One; someone did make a TT that used a laser beam instead of a stylus. The product had a very short lifetime due to reasons unknown.
Two; the 'image' as you call it has to physically represent the music. This can done in one of three ways - (1) the traditional method of a vinyl where the groves are used; (2) some magnetic form that can be used to represent the music; and (3) digital form.
If you delve deep into the construction of a CD, you will notice that the representation is actually physical - a minuscule hole in the media that represents a zero or a one.
Any form of representation other than a empirically physical form such as the vinyl groves has to be digital.
A well recorded digital media at high sampling rates is very very close to the analogue original, and the difference is very difficult to identify. In the recent past, more and more reviewers have realised that a high sampled digital version stored on a hard disk removes the limitation of a media such as CD/DVD, and they were able to hear a larger sound stage as well as more detail than not only the equivalent Redbook CD, but in many cases even the equivalent vinyl. Before jumping on me, it is wise to remember a disk has no limitation of the data size. You can, theoretically, store a single song on something like 120MB size - three times more than the compressed sized used in a CD. This technology has moved very strongly into the 7.1 domain where HD audio of a movie is stored in something like 20GB of space. That is roughly 170MB per minute per track. Compare this to a Redbook CD that stores 2 tracks of roughly 3 minutes in about 40MB.
The main issue in the digital domain is compression. As media reaches higher capacities, the sheer volume of data that can be stored will make analogue look like a steam engine.
What surprises me that no one has thought of releasing a music disc using Blu-Ray. They can record and store the music without any compression and at sampling rates very very very close to the analogue wave form. That will, as I said before, make all TTs beg for mercy.
Thanks to all the forum members on enligthning me on this topic. Venkatcr sorry for asking such a vague question but I din had any knowledge on Vinyl. I was planning to buy a dedicated CDP and suddenly I discovered Vinyl hence I thought of why not to take a advice from audio guru's here. Now I am clear on what I want and I will stick to dedicated CDP and a good stereo amp. I feel it's more VFM. Thanks once again for all your inputs.
Santosh
Except that music doesn't come in bits, as it is not, itself, digital.1. What is HRx? HRx is our trade name for high resolution audio WAV files on a DVD-R data disc. These files contain exact bit-for-bit copies of Reference Recordings master recordings. They are the ultimate in fidelity for two-channel sound!
