Laptop to LCD
vix41085
india
hi i hv lg 32inch jazz lcd and acer aspire 5745 laptop.i hv so many blyray and hd movies on my lappy.i want that on my lcd wid no quality loss.when i try using hdmi cable the quality not good as laptop screen.
plz someone help me. coz i wanted to c that on my lcd.
why isint it good ???
resolution issue ??
blur images ??
soft ??
colour reprocution ??
also laptop might have a glossy screen..
change settings on tv
change aspect ratio to just scan.
and connect to hdmi -3 that is also a pc -hdmi port.. will work better..
look behind the tv.. hdmi-3 will also show as pc.. connect to that hdmi..
ratio select ( just scan) reboot system while hdmi connected then see.. if its any better.
set to natural or standard..
noise off.. black level low..
tru motion to low..
dynamic colour and contrast to med...
that wud be it
energy saving to min if bright lit room else to medium..
thats what i use and i find it good with xtreamer and my laptop and tata sky hd and
dvdp i use cinema mode with diff settings..
