Someone correct me if I am wrong, but I thought the NTSC/Pal thing is only relevant if you're using the RF (antannae) input, and not for component or HDMI. That being said, most modern LCD's are multi-system. They can support both 50Hz/60Hz inputs.
you are very much correct. concept of PAL/NTSC is no longer valid in digital world. you just need to get HD set-top box and connect your LCD with HDMI cable. it will work. most of guys who are bringing LCD from US always face this dilemna.
If PAL/NTSC were not an issue in the digital domain, why would you need such a device ?
I would be interested in hearing whether the people claiming that PAL/NTSC is not an issue in the digital domain, have ever actually tested their hypothesis.
I struggled with an NTSC only TV from US for over a year, and finally gave up.
Have a look at the reviews for the Altona device on Amazon. A number of people across the world who state clearly that HDMI / HD programming does not help. To use a US / NTSC only TV in a PAL country, you need a frame rate converter - 50hz to 60hz. Indians who have brught back a TV from US have also posted.
OK I stand corrected! I guess the next gen of multiformat TV's will have switchable input frequencies (especially in 3D sets) where you can switch between 50/100 Hz and 60/120Hz. Computer monitors have supported multiple frequencies since ages now.
to correct u all guys who have a wrong understanding of HDMI, though it is HDMI the signal which it carries from the STB is a PAL signal and the TV from US is capable of handling NTSC signal. Having said that we are feeding a PAL signal to a NTSC tuner which is no way going to work unless or until we use a converter like Altona or etc.
