Led TV switches on/off automatically help?
  • Thread starter Thread starter Deleted member 71491
  • Start date Start date
D
Guest
Hi i am using the same V-Guard Crystal Plus Voltage Stabilizer for my brother's 32" tv samsung f5000 but still tv is getting switched off once in 10-15 mins what might be the problem:sad:.There are no timers set. help me out guys
If the voltage input is more then the stabilizers voltage range then the output will be cut off so check the voltage in your area.
Some tvs may also have a presence sensor where if it doesn't notice any one moving in the room it will switch off after a while.
Thanks all ..i checked there is no presence sensor with this model..I will check for high voltage reading and the remote issue..thanks again for quick reply
Its not problem with voltage readings or Stabilizer.I even gave direct connection without Stabilizer still the same problem persist any suggestions what might be the problem?has any one faced this issue.?
Are you sure Tv's Pin is correctly fitting in to the socket? May sound funny but just make sure by inserting some filler or try widening the gap between 2 pin nodes. I had experienced this for some other device even if it looked fitted good and current was getting cut after some time due to loose contact.
