sunster
Any online stores or dealers for fixed wall mounting brackets in Mumbai ? For LG 65 C9 Oled
Lg provides an excellent wall mount so don’t worry.Any online stores or dealers for fixed wall mounting brackets in Mumbai ? For LG 65 C9 Oled
They will provide free of cost during installation. Still if you need it for some reason, I have one.Any online stores or dealers for fixed wall mounting brackets in Mumbai ? For LG 65 C9 Oled
do you have a pic of your wall mount bracketThey will provide free of cost during installation. Still if you need it for some reason, I have one.
You can push it close to the wall. Don’t go for fixed you need few inches gap for sure. Also for changing cables it will be much usefulBut that is the movable one. I want one thats fixed and without much gap from TV to wall
The bracket that comes with LG looks way better then after market and is more compact. The after market 65 inch brackets are bulky and doesn’t look good as the lg. Just go with the LG wall mount that’s includedYes you are right. I have a 43 inch LG 4k LED tv installed in my bedroom with the same bracket but it is not pleasing aesthetically and the wife will cause a furore
It won’t have a swing arm where you can pull very long. Few inches front and can be tilted on all sidesis the LG one the movable one ? Which swivels?
Ok would you mind send me a pic of your setup just the part where the tv is wall mounted and the gap from the wall.It won’t have a swing arm where you can pull very long. Few inches front and can be tilted on all sides
Happy to helpWow thanks for the effort. Now I have a proper perspective.
Is this a 55 or 65?see my current setup. Need the new LG also to fit like thisView attachment 42342
Looks like it will protrude a lot. Mine has very less space. Moreover the speakers will go and the new speakers will be below the tv exposing all the cables etc. let’s see View attachment 42344
