funnyprogrammer
Hello All,
I have a 5.1 setup in a dedicated light-controlled small room (11*11). I was using an LG C1 48 inches and now planning to upgrade to a bigger TV.
My viewing distance is 8 feet and my use case is 70 percent movies, 30 percent gaming.
Here are my options
I was set on buying LG C3 but it is out of stock in Reliance Digital in Hyderabad and they suggested going with S90C or higher-end G3.
I don't want to spend more than 2 lacs for 65 inches TV, I can buy an X90L 75-inch for the same.
For some reason, I don't have a good impression of Samsung TVs in general but after seeing reviews looks like it is a better TV than the LG C3 and cheaper as well.
I don't need a DTS passthrough feature as I connect devices via AVR.
Another limitation of S90c is the lack of Dolby vision, which I am not sure if it makes a difference.
How can I make sure to get a second-generation panel with 65 S90c?
I use AppleTV so I am not concerned about TV OS at all.
Should I just go with the known devil(C3) or try something new?
Please suggest.
Here are my options
- * LG C3 65 inch - 164k after cashback (Bajaj electronics)
- * Samsung S90C 65 inch - 145k after cashback (Reliance)
- Sony X90L 65 inch - 130k
Please suggest.
