There are a couple of youtube videos that show how to do it and you need the standard remote for it. The magic remote cannot do it AFAIK.Do u know the process to set it to 0?
You are doing the right thing.For some reason the installation was cancelled today by Flipkart's system. LG couldn't send one today either. I have started the return process for the TV. I don't think I'll be at peace with it. Flipkart is saying that a technician will come and check if the product is fine or not. I anticipate fighting Flipkart to take the TV back. Why should I accept an expensive TV with a broken seal when even no one would accept even a cheap mobile phone if it's delivered with a broken sea? Will fight. Then will consider if I should wait and take the 2019 models during diwali. Anyway, be wary of online retailers too. Brick and mortar stores can send display items. Online retailers can send returned and opened items.
I always buy expensive items from brick and mortar stores. They always match the price and many times go lower with some convincing. How much did you got it for on flipkart?
It can be done through service remote. My first unit had a thin vertical line on it and when LG engineer triggered the test patterns from his service remote all my settings and logins were gone. The TV was factory reset including the usage hours which went back to 0.Do u know the process to set it to 0?
If you raise this with LG directly they will send u a replacement unit.For some reason the installation was cancelled today by Flipkart's system. LG couldn't send one today either. I have started the return process for the TV. I don't think I'll be at peace with it. Flipkart is saying that a technician will come and check if the product is fine or not. I anticipate fighting Flipkart to take the TV back. Why should I accept an expensive TV with a broken seal when even no one would accept even a cheap mobile phone if it's delivered with a broken sea? Will fight. Then will consider if I should wait and take the 2019 models during diwali. Anyway, be wary of online retailers too. Brick and mortar stores can send display items. Online retailers can send returned and opened items.
Where did you find that info? I didn’t see that anywhere about the red pixels.It's gone back now.
I'll take the 2019 model only now. Also, the red pixel seems to have been increased size this year too, which means that burn-in will happen later than 2018 models.
Omg, do you have extended warranty?This isnt a C8 but a B6. I closed my house for a month as we had to leave due to my father falling seriously ill. The tv was fine and working perfectly.
We got home yesterday and went thru the motions of cleaning the house etc and finally today, the wife switched on the tv to decompress. I was horrified to see the screen.
Lines of dead pixels and gray vertical bars!
Just noticed - Blue is smaller and red and green are larger compared to C8.Exactly. It's not really being mentioned in reviews. However, you can compare images on Rtings.com of the pixel structure. The blue seems to be slightly smaller, and the red and the white subpixel slightly bigger. There's also an OLED technology thread on avsforum where this has been mentioned.
Isn't subtitle dynamic , means keep changing with every scene? How the hell someone get that as a burn in. He got stuck on a scene forever ?Which will make it even more burn-im resistant. My biggest fear is subtitles. I'll be using them on almost all the content I watch. A user has reported burn-in at 7000 hours with subtitles on Rtings. That was a 2017 model if I'm not mistaken and white subtitles too. They are going to be semi-transparent on Amazon and Netflix for me. That combined with two years of increase in size of subpixel that burn out the fastest should give me 10,000 hours at least of burn-in free usage with regards to subtitles. That's like 5-6 years for my usage.
Hope your father is well now.
The same pixels are being used to display pure white at a higher frequency than rest of the screen. Burn-in is cumulative. 7000 hours is a long time. Over time, those pixels worn out faster. You can check images on Rtings' 07 Jan 2019 video.
Now the question is that whether displaying the subtitles burnt the white subpixel or the red one. I think white because it's visible on many colors except blue. Not totally sure. Anyway, compared to the 2017 model, both the white and red subpixels are now bigger and then using semi transparent subtitles will also help in prolonging the burn-in free period.
Also, Rtings have published their B9 review. It's mostly in line with expectations, except one major disappoint in the gradient test. It's worse than even B8. If this isn't because of panel variance, LG seems to be intentionally making B models worse than C ones.
That's really unfortunate. I know the pain. I had the same situation with an iphone and a macbook in the past. Weeks after warranty they died. And nothing could be done.He's better now, thank you.
I got the 2 year warranty... it expired last year![]()
When u talk about expectations, another fact is the best lcd u can compare an oled with wont be even half way through any expectation in terms of color accuracy. I strongly believe this guy pos
