LG PA75U - Impressions
I bought this projector recently. I'm trying to share the display from my Samsung Tab3(311) which has WiDi to this projector using the WiDi function. Both the devices can detect each other but I'm not able to see the screen. Not sure if I followed the steps as per projector manual. Can some one help me on this?
I want to see my tablet screen in my projector.
Also I would like to know how to check if the projector output resolution is set to WXGA (1280 x 800)
Can some one post the expert settings for Movie?
Can some one help me in buying projector pulldown screen 110inches 16.9 format or 120inches 4.3 format. Where cani buy in less price , madras or bangalore. Also I need 15m hdmi 1.4v cable. I checked deltapage website.
You can check eBay . in.. 120" instalock is available in 4:3 aspect ratio.... Also deltapage has 110" available in 16:9aspect ratio...
I'm referring to deltapage website and projector manual before zeroin on the screen size and cable length. I used projector central to calculate the screen size and distance from projector lens.
Any inputs will be helpful. The HDMI cable of length 15m, can we buy from ebay as some of the model costs <2000Rs against to DAC which is Rs.6850
Also I need to buy 15m laptop power cord which is circular female 3pin.
I'm making reference to deltapage website and projector guide before zeroin on the monitor size and wire duration.
I already bought my projector. Projector mount, I bought from SP road for Rs.950/- which anyone can assemble by self without any external tools. Finally you can call a electrician or carpenter to put 4holes in wall to fix it.
Now I'm looking to buy 10x8feet manual screen. Can some one quote the vendor and right price point?
This projector is just great. Almost all my files in USB can be viewed.
Hi Guys ,
Need ur expert help I am getting New LG PA75U for Rs 45000 landed cost to India. Is this a good deal and also is the antenna that we get with this model any use in India.
Would appreciate expert inputs from people who have this projector
Hi Guys ,
I had the same model. The price you have quoted is high given that projector model is aged and better model from same brand is already available (PA85U)
The projector does have good connectivity like HDMI and USB besides speaker. But my remote died with in 1week in india and I'm using the bluetooth remote for my usage. The antennae is of no use to my knowledge as its mainly for US broadcast. Also you can connect the RF out from you satellite STB to the projector. When my remote died, I called LG local help, they asked 2500Rs basic charge + spare charge which is to be imported. I gave up.
In my personal opinion the price is high. Can you give the price break up? how did you ordered? I bought it for 500USD.
