LG PQ 60 Service Menu
regenade
Anyone has idea on how to access the service menu on the LG PQ 60....the usual trick of menu button didn;t work :(
regenade
it wont.. used to work on old tv's .. i have been trying to get hold of the service menu since months.. no go...
i got a LG LH60YR..
new menu can be access only through psiloc IR remote on nokia S60v3 devices..
u can select service profile in it once the device it detected. .however if you are planning to change the settings to play HD through USB .. that setting has been removed all together from the menu..
