does powerdvd 9 play mkv's? i have an oem version,it doesn't.
any workaround?
No it doesn't.
There is a seperate version with HD support and it is more costly.
any workaround?
No it doesn't.
could you post a link to that specific product with hd spport, it seems the workaround is to rename the mkv to avi or divx..it didn't work for me :lol:
I guess you need to install some additional software before renaming your file,
see
WikiAnswers - How do you play mkv with powerdvd
not sure though, got this link by googling, have not tried it personally
cheers
VLC 1.0 has no prob with my HTPC,running freely.
The ultra editions already have the codecs shipped. You only need to rename if you have ultra. The deluxe does not have this support and have to rely on external codecs.
Refer,
PowerDVD 9 DVD Player Software Watch DVDs and Blu-ray Discs on your PC | CyberLink
The versions with Blu-Ray playback have this capability.
BTW, If you have downloaded the trial, you will not be able to playback MKVs. Trial versions are deluxe. The ultra is >100mb in size, check the size of your installer.
MPC-HC too plays without an issue.
Yes,better for vid than vlc,but sound is weak.VLC 5.1 sounds better than MPC-HC.
