LM3886 Mono Amplifier
suds07
India
Here is my version of DIY LM3886 Amplifier
schematic and PCB layout attached, I made prototype, there is no audiable distortion with input floating, good response with bass, guitar and high frequency music, schematic is smililar to Gainclone LM3886 amp.
Suds
I get it done from a manufacturer in chickpet "Vishal International"
they are expensive, so I combine multuple types of PCB for prototyping.
Re: LM3886 PCB
I get them made from Manufacturer, I only Clone / Re-design them.
Does he have a website? Will he take an order remotely, if I email him the Eagle CAD files or the Gerber files, say?
Remotely does not work with him, he delays a lot, need to follow regularly, he takes some amount in advance, its better to find some manufacturer at your location.
I guess my safest bet then will be PCBPower. They take orders over the Web, and operate in India. Never used them, though.
i have had a very good experience with PCBpower. Very neat production.
i guess they are a little expensive and would be VFM if there is a large quantity.
hope this helps :)
I have quote from them, yes they are expensive..
Quite natural! that is the economics of mass production. But I dont think you need external help for a PCB of this size and complexity. simple laser print-hot transfer-FeCl2-varnish coating method is enough for this. for double sided just drill one side before transfering the other side.
Hi Sudhir,
It's a small world !
I bought a kit from your ebay store - didnt know you are on HFV !!
I must admit - super prompt responses and detailed replies for my newbie questions.
All the best !
