Logitech Z906 wall mount setup
sgmane
Any of the FM having Logitech Z906 did a wall mount? If so, do provide me the information.
Also would like to extend the speaker wires at the rear. Any options?
On some latest info, i see that logitech provides wall mount brackets/screws in the product. But the one i got did not have them. Its unfortunate that logitech did not care about the customer's at that point of time!
This is a wonderful piece of HT for its price (not in comparison with latest price though!!) and i want to exploit it with by going for wall mount and experience the movies in DTS/Dolby Digital sound!
Any leads?
Thanks. Yes i shall check with Tono's. What about the speaker wire? Does is suffice for your rear setup? And also latest updates from our FM magma about speaker wall mounts are also available.
though rear speaker wires are not sufficient for me, i am able to manage it now as i am planning to upgrade from these to HTiB/AVR+speaker system very soon.
You can check this link for specification of wires of Z906.
The same can be purchased from hifimart if you need.
Thanks again. Yes i had check on the logitech forum earlier. Some guy had got the 16 gauge. Let me check on this further. The wall brackets pointers had got me to narrow down. So the wires are pending now.
Does anyone know where can I buy a new z906 for a good price . I see ebay and all listings are more than 23 K which is wayy too expensive .
