kiranM
i have Optoma full hd projector but would like to upgrade to 4K
Next to sony epson 9400 is v good .I'm using it v happy about it.price difference between Epson and sony is almost double.epson 1.9 whereas sony is 3.6 best price from the link as suggested by one of fm from here.How about epson TW9400
few days back only I did a comparison between BenQ W1700 (4k) and BenQ 1070 (1080p),Although I dont own a projector, but I read somewhere that for 100inch screen, 1080p and 4k wont have much diff.
I have not validated this anywhere, but someone using 4k projector can throw some light on this.
Have you planning to audition these projector before spend such a huge amount?
what was the screen size?few days back only I did a comparison between BenQ W1700 (4k) and BenQ 1070 (1080p),
the difference in sharpness was VERY visible
tried it on 125 inch Diagonal and 100 inch diagonalwhat was the screen size?
That depends on distance of viewing..Although I dont own a projector, but I read somewhere that for 100inch screen, 1080p and 4k wont have much diff.
his room size is 21x12 and I assume that he will be viewing from a distance of about 18ft. so, I thought that diff wont be noticable from that distamce. But since other confirmed that they can see a visible diff.That depends on distance of viewing..
1080 and 4k will make difference on a 65" TV is one sits close enough to the screen.
1500 lumens is quite less, my optoma hd25 claims 2500lumens, but that too is peak momentary brightness and even at 2500 rated, i find it to be barely passable. Your milage may vary.I am considering an upgrade to the sony 270. Trying to get a demo from the dealer, meanwhile if anyone has auditioned this model - can you advise on its brightness? Concerned that it is only rated at 1500 lumens (does it look dim?). Also if anyone has done a comparison of this to the epson 9400 (I know that is not a native 4k), I would be very interested in your opinion, specifically in 4k resolution and black levels. My viewing distance is 13' from a 110" elite grey screen in a 100% light controlled room.
Sid
