Looking for 5.1 speakers
ratishmohan
Pune
Hi friends,
I just ordered denon x3500h from Europe and will be getting it by 28th April. I hope I made a good choice buying it. Now looking to make 5.1 system. Need your help on following.
- I am assuming that The avr should work fine in India, please suggest any care I may need to take.
- regarding power supply. Should I take special care? Would connecting both avr and sub to single extension of 16 Ampere switch
- need suggestion on speakers i may start with 3.1 (not sure if 3.1 is correct representation) 2 front, center and sub. Budget around 30 to 40k. I can stretch a bit if there is significant improvement.
- suggestion on surround but may be later once I feel to add them.
- any place in Pune where I can demo the suggested speakers. Or else Mumbai stores.
- suggestion wrt writing, casing, connectors
My room size is 12x20 with ~12 feet being viewing distance from sofa. 47 inch lg led TV wall mounted right in middle. Would love to add projector and screen in future. And may be 2 ceiling speakers. But only if 5.1 works out with good quality asi cannot make drawing room much acoustic controlled.
Thank you in advance!
Ratish
Pune
Indeed a good choice..
You should be able to complete a 5.0 set-up in you budget (or) if you can overshoot slightly from Taga Harmony Platinum series, Mission..
For wires, you can opt for amazon basics depending on distance required & correct gauge.. For connectors, you can use MX banana plugs, cost effective ones..
Casing can be done locally with help of plumber..
Thank you elengoas!! That helps.
Any place where I can get demo? Pune or Mumbai?
Any other options I took demo of monitor audio radius series but got no other brand's demo.. They seemed good. How do they compare to taga Harmony Platinum series?
Hi friends, any place in pune or Mumbai, where I can audition klipsch, B&W, Wharf date, Taga Harmony or other well known brands?
Where does monitor audio stand compared to other top brands?
What speaker specs should I look for to setup with my denon x3500h? Mainly for movies, TV series from Netflix and 25% for music.
Hi friends,
Good? For a 5.1 that is one hell of a receiver and a beast
Dali zensor series and q acoustics will be an excellent choice. For wiring you need to go for OFC and C&E will be excellent.
Thank you dear. Any idea of store near Pune or Mumbai where I may get audition of above brand speakers? Have heard a lot about them but could not find place to listen to these brands yet. Also looking for Polk audio audition.
Well check with members who are located in Pune and mumbai.
Here is a showroom in Pune (Personally I haven't yet visited)
AVXellence, Level One, Satguru Centre, Bund Garden Road, Bund Garden, Sangamvadi, Pune, Maharashtra 411001.
Contact: +91 20 2616 5000
Map: https://goo.gl/maps/AHPvd69QXDk1ktB36
Thanks I visited them at their older location. Seems they have moved to new place. I hope they have more demos to show. Will visit them soon
Start with fronts only or fronts and centre and slowly build as budget permits. Get a good sub.
I know you will be all excited and unable to wait long to set up the system :)
But better to have a good system even if it takes time rather than an average one immediately.
Do consider buying preowned. Some good deals do come up here. Look up olx/qikr also but only if you can check before buying.
https://www.hifivision.com/threads/velodyne-impact-10.74520/
https://www.hifivision.com/threads/elac-debut-series-5-0-speakers.74401/
Agree. Planning to do so now.
1. 2 front and center
2. Subwoofer 12"
3. 2 surround.
Should I buy same brand front and center? Some people say it's good to ensure their tone matches well
For cables planning to buy Amazon basics 14 Guage speaker wire. Anybody used them or should I put for some other brand. There were couple others..
C&e 14 Guage cl2
Mediabridge 14 Guage
Center speaker is available for sale, Please check HFV classified.
I tested, tonal would affect little. but if center is good, it will dominate Front speakers and Vocal would be awesome.
Thank you.. Then I would go with better option. I have heard about monoprice so may go with this.
I have unused (new) DAC speaker cable 10 meter for sale. Let me know it would interest you.
Hi all. After reading so much about so many speakers and subwoofer, my budget is going crazy. I will soon list my shortlisted set soon. Unfortunately no place to get a demo.. :(
I wish there be any stores like richer sounds UK in India.. Almost everything is available..
Any smart way to get them from US or UK? Already getting in touch with my friends and families traveling to get them, but not very convenient for most.
Make a trip to Mumbai......
Visit the many dealers around......here are some which are well known.....
Total Home Theatres (Nariman Point South Mumbai) http://www.totalhometheatres.com/contact-us.html
ProFx (Polk Audio, Yamaha etc) https://www.profx.com/ should have multiple stores in India
Fair Deal (Crawford Market and Vile Parle West Mumbai)
The Den Mumbai http://thedenindia.com/
Audio Vision India Mumbai https://www.audiovisionindia.com/
Cinebels for Klipsch speakers....http://www.cinebels.com/
MZ Audio Bandra Mumbai http://mzaudiodistribution.co.in/
Audition and decide....all the best!
Awesome.. Thanks efernand..
Currently down with fractured arm. Will visit Mumbai in June specially for this. Have been listing stores.. Added them..
