Looking to buy a Home Cinema!
mangini
france
hello,
i own an LG TV 42lm3400 (no hdmi arc but 1 optical yes)
I want to buy a home cinema. i was looking on amazon i found Sony BDV-N790 Sony BDV-N990 but after reading about those it might not be the best choice.
I want a home cinema to listen to music, bluray concerts and movies.
Apparently the way to go is an ampli (denon) and speakers but i dont know precisely which model.
my budget is around 600 euros.
thanks ;)
searching a bit i found this YAMAHA YHT-298 YAMAHA YHT-298
ONKYO HT-S4505
what do you guys think?
For HT systems always look for specialized brands like Onkyo, Denon, Yamaha, Pioneer etc. A few suggested models are Onkyo 3500, Denon 1312XP, Yamha YHT 296/298. Going separates like Denon 1612 AVR and Boston Acoustics XS5.1 speakers will give you better sound quality than the before mentioned HTiBs.
Hi welcome to HiFiVision.....
For 600 Euros you can always go for the separate amplifier and speaker packages.
I have given some suggestions below from you can purchase under your budget. You can get any one of the AV Receivers with speaker package which will serve you well into future.
Denon AVR1513 Ampli-tuner Audio/Vido Surround 5.1 5 x 110 W 4 HDMI: Amazon.fr: High-tech
http://www.amazon.fr/Yamaha-RX-V373-Ampli-canaux-Titane/dp/B007Q058Z4/ref=sr_1_4?s=electronics&ie=UTF8&qid=1357485266&sr=1-4
Wharfedale Crystal 3 5.0 Surround-Set rosewood: Amazon.fr: Home cinma & Hi-Fi
Please get in touch here for any doubts, our Fellow members are always at help...
thanks for all the suggestions.
i realised i may have to settle with something like the Yamaha Yht 298 or Onkyo 3505 they are like 380 euros.
So of course now im wondering which one is better?
they can read flac from usb?
First take a audition of both the HTs, listen them. Whatever you like take it. There is nothing different between these two HTs.
If you want the home theater for both music & movies then, its better to go with Yamaha YHT-298 package. The Yamaha is more suitable than the Onkyo for both music & movies.
The Onkyo HT-S4505's movie performance is very good and music is at par.
There is a LG "sponsored" forum here, you can find it at LG World Record . You will find a LG representative there - who answers product related question - especially regarding LG Smart TVs. Maybe you can put your question there.
Of course, you have already got some very good suggestions here already!
thanks for the hint. Although my next TV wont be a LG wasnt too thrilled to find out it wasnt Arc compatible...
