After using Windows for 15+ years, time has come to change the OS. Installing the latest Mac OS X Leopard is much easier now. Checkout the links below which will help you to get it installed.
tonymacx86 Blog: CustoMac
InsanelyMac
Lifehacker, tips and downloads for getting things done
Also check the attached images of Hackinstosh desktop. In one of the image, you can see that i am running three operating systems simultaneously using VMWare Unify. You can contact me if you need help.
Sudhish.
InsanelyMac
Sudhish.
