AbhishekAshu
Low budget 5.1.4 setup for movies and gaming
what is the budgetLow budget 5.1.4 setup for movies and gaming
As low as possiblewhat is the budget
Room size 16*14 bed room need only AV receiver and speakersAs low as possible
Sir I was thinking Budget of 3lakh for the setup.First take time and decide on budget
For a 16x14 room, not sure if satellite speakers can fill the room.
Audition a lot of speakrs and see what you like.
Otherwise you can go for used speakers(bookshelf) , that is value for money.
For atmos you will have to spend on a good av receiver. A 9 channel should do, but make sure that the outputs are assignable.
What will be your media source?
Streaming or 4k Bluray disk?
3lakh is a good budget you can get a lot in it. If I were you I'd buy used.Sir I was thinking Budget of 3lakh for the setup.
1) I was thinking avr Denon x3700h or x3800h but need recommendation for speakers.
2)focus will be for movies(ott) and gaming.
Go for Denon 3800h or onkyo rz50.And you can cgeck pioneer 9.2 Amplifiers zldo.Sir I was thinking Budget of 3lakh for the setup.
Wat speakers should a look for any suggestions3lakh is a good budget you can get a lot in it. If I were you I'd buy used.
Olx and Facebook marketplace par dekho. You'll be limited to what you find thereWat speakers should a look for any suggestions
You can have a look at this thread too. There are lot of such posts, searching would also give you some ideas.Sir I was thinking Budget of 3lakh for the setup.
