jeffmartin8219
Hello
Wondering if anyone has had any luck resolving protection errors on the Marantz SR series of AVR.
First this is not a thermal protection it's the .5 second flash. The unit will turn on run for a random amount of time or sometimes fail right after boot up is complete with a loud pop from all connected speakers and power down. This happens with all connections hooked up or removed so it is not an external component causing the issue. Unfortunately Marantz does not have any major components left for these units so I'm hoping someone has had luck fixing this issue.
I just ordered a "like new" returned NR1510 off Amazon to use until I can figure this out and it had the same issue as soon as I plugged it in! This one fail after boot up everytime.
Is this a common issue with Marantz units?
Thanks in advance for any advice.
