elangoas
After using the Audyssey Multi EQ mobile app & reading thru many threads/posts/videos on AVSforum / HTshack/ Youtube on REW guide, I wanted to give REW a try..
Some AVSforum members have put enormous effort in compiling detailed guide :clapping:.. Here is the link - http://www.avsforum.com/forum/91-au...surement-techniques-how-interpret-graphs.html (Courtesy AVSforum)
https://www.dropbox.com/s/zdhq72a1puyyxpr/REW 101 HTS Current Version.pdf?dl=0
All i have is an Audyssey Microphone that came with my Denon AVR x3300 & a PC with HDMI out(Nvidia Graphics card), so decided to get started with it..
Plugged it in to Mic in on my Win7-PC and made the necessary settings under recording devices..
- Set volume to 75
- Mic boost to 0%
I also downloaded ASIO4ALL and configured the output settings in REW per the guide..
When i clicked calibrate the Mic, REW popped up with a msg that "maximim SPL with this calibration is 76db. If you need to measure higher SPL the input sensitivity will need to be reduced".
When volume on AVR was -15db approx, test tone was showing -12db (out) from REW, the Level in was -28db and Ref in -30db...REW SPL meter was showing 58db..
Am not sure if i missed any setting in REW, could someone help here...
I wanted to measure sub response, re-position for a better response if reqd..
- Set volume to 75
- Mic boost to 0%
