media player with good digital audio out
mukesh soni
Borivali Mumbai
hi friends
I am little confused
(I want to buy)
media player
inbuilt HDD NOT required
max format support
budget max 10/15k
please help
Hi sonosphere,
It is primarily for video use. If your purpose is audio, you may find it short of mark. I don't think it will beat the Xonar card. AFAIK it won't support FLAC.
If you want you can use a free FLAC to ALAC converter and test it.
Optical(toslink) is jittery by design and for high quality music reproduction, ignore this interface. It is impossible to get an optical interface to under 300ps of jitter.
If you must have a good music playing media player, look for the Cambridge NP30. It sounds pretty damn good when used with the coax digital out to an external dac.
