liverpool_for_life
First steps first:
Before I decide on what HT system I'd like to get, I wanted some feedback on whether my living room lends itself to the setup of a 5.1 HT system.
The room is 12 ft long (listening distance slightly shorter because of a sofa lined up right against the wall opposite to the TV mount). Floor standers (mostly) ruled out because of a door 3 ft wide opening in to the room, leaving us only 2 ft from where the door ends to one of the TV edges. The width of the room is 13.5 ft, although this is effectively 10.5 ft for purposes of speaker placement (front and rear) because of the presence of 2 doors on both walls about 3 ft wide. The ceiling is about 10 ft high.
There are 2 single-seater sofas against the wall to the left of the TV (from viewing position). On the other side, there is a door + wall portion that is roughly 6 ft wide. The rest of that side is open and leads to the dining.
Given all of this, is a meaningful 5.1 HT setup possible? Thanks in advance for all your responses!
